303D SMD Rework Station Specifications?
A customer of ours brought this unit in to be calibrated. I see no +/- specifications and would like to know what you would test this unit to that would make it “good”.
Datasheet, certificate of calibration, procedure… Anything would be helpful. Otherwise, this is just a Functional-Check only type of unit which works too. I’m just covering my bases.
Also, thanks for the down-to-Earth writing style in the manual. It was enjoyable to read. Thank you.
The run-through is basically just to set it to a reasonable rework temp and ensure it is outputting enough heat/flow to melt solder; these are fairly imprecise by their nature (different nozzles and such alter the heat profile drastically)
If not, there isn’t any real calibration you’d just try to find a replacement heating element How to Use a Hot Air Rework Station - SparkFun Learn
There’s also another barebones manual at the end of the hookup guide but it doesn’t mention a lot
Treating the 303D as functional-check only seems like the honest approach. Since nozzle choice and airflow shift the profile so much, chasing a tight ± spec in °C would be misleading anyway. If you want something documented for the customer, I’d record setpoint vs. measured tip air temp across a few settings and note the nozzle and flow used, so the numbers are reproducible. On the heating element side, a simple resistance and current draw check catches most failures before you bother with a thermocouple comparison. Curious whether you’ve seen much drift on these units over time.
Mr. Parker,
I appreciate the input. This was the first unit of this type I’ve seen come in and once we told the customer there was nothing to check, they requested the unit back, so there won’t be any recorded data unfortunately.
