Arduino doesn't recognize microMod nRF52840 board
I’ve trying to start a project using the MicroMod nRF52840 (WRL-16984) on the MicroMod Input and Display Board (DEV-16985), but the directions for installing the SF_MM_nRF52840_PB folder don’t agree with the location/path I find on my Win11 laptop.
I’m using Arduino IDE 2.3.10
the folder ARDUINO_NANO33BLE path is: C:\Users\av8rr\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.6.0\variants
I have copied this folder into a new folder named SF_MM_nRF52840_PB and then copied the 3 files:
pins_arduino.h
variant.cpp
boards.txt
fromMicroMod_Processor_Board-nRF52840-master.zip which I downloaded earlier today.
Earlier, I had also installed Arduino Mbed OS Nano Boards v4.6.0.
After closing and re-launching the Arduino IDE, I still don’t see an option for the Sparkfun MicroMod nRF52840 Processor Board as a possible board selection option.
Any help to show me what I’m doing wrong would be appreciated. Thanks in advance.
Windows 12 laptop???
Good catch. Windows 11. I’ve corrected the post. Thanks.
Ok, I think I see where you may have tripped up - you put the variant.cpp and pins_arduin.h in the right place ('C:\Users\av8rr\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano\4.6.0\variants\ → the newly made SF_MM_nRF52840_PB folder, but the boards.txt goes in the C:\Users\av8rr\AppData\Local\Arduino15\packages\arduino\hardware\mbed_nano folder (up one level in the directory)
Then it should appear
BINGO! That was it. Thank you so very much. Have a nice evening.
Roman
