Hi everyone,
I’m trying to work out what hardware I need to use the ESP32_BluetoothSerial example from the SparkFun Apple Accessory library to send NMEA location data to an iPhone. I’m stuck on the Auth 3.0 coprocessor rather than the ESP32 code.
I found the July discussion about Android and iOS support, which explains the difference between BLE access in SW Maps and native iOS support on newer MFi-certified products. That helped, but I couldn’t find a current answer about getting authentication hardware for a custom prototype.
My board is an ESP32 DevKit V1 with 4 MB flash. The reference example compiles with Arduino ESP32 3.0.7 / IDF 5.1, Apple Accessory library 3.0.8 and Auth library 1.0.0. I also tested a separate UART/NMEA input adaptation on the board with Bluetooth disabled. That part works, but I haven’t tested iAP2 authentication or location delivery to iOS because I don’t have the authentication chip or product configuration. The phone I’m testing with runs iOS 27.0.1.
Could someone point me in the right direction on a few things?
- Does SparkFun sell or recommend an Auth 3.0 evaluation board or breakout that works with this example? An exact part number would help.
- Can an individual developer obtain one for a prototype, or do I need MFi membership and an approved product plan first?
- Where should I get the current official driver, wiring documentation (especially supply and I2C voltage levels), and guidance on the required accessory configuration? Is this example still supported?
If this route is only available to approved MFi manufacturers, that would be useful to know before I buy more parts. I’m mainly looking for the supported hardware and documentation path.
