Can Openlog Artemis log simultaneously fourSparkFun GNSS Breakout SAM-M8Q (Qwiic)?
I need to log four SAM-M8Q with different orientation with one openlog Artemis.
If i use qwiic mux does the OpenLog Artemis will recognize and log all four SAM-M8Q ?
You should be able to, though do note the logging rate may pose issues (1Hz each should be fine, trying 5-10 each will likely overload or run into sync issues)
You’ll want to leave the i2c pull-up resistors on the mux intact but cut the 2 small traces between the pads on each of the SAM-M8Q’s (labeled I2C) to disable them
Pre-emptively: If you run into power issues (say hooking up 3 at once works but not 4) you might want to disable some of the LEDs (refer to link above), but I believe it should work with 4
Many thanks for good advices.
