COM-13014 (SKU 13014): is the terminal a 3.2 mm spade or a 2.8 mm #110 tab?
On the COM-13014 page (Mini Microswitch - SPDT (Offset Lever, 2-Pack) - SparkFun Electronics) the features list says “Connector Style: 3.2mm Width Spade Terminals.” The dimensional drawing gives the body as 19.9 mm long and 6.4 mm thick, with Ø2.4 mm mounting holes on 9.5 mm centers, and it draws each terminal as a blade with a hole, but it never dimensions that blade. Those body numbers line up with the Omron SS subminiature outline (19.8 mm long, 6.4 mm thick, Ø2.4 mm holes on 9.5 mm centers), whose quick-connect option is a #110 tab, 0.110 in / 2.8 mm wide. The standard female quick-disconnect widths are 2.8 mm (#110), 4.8 mm (#187), and 6.3 mm (#250), so 3.2 mm is not a size a mating connector is made in, and the housing outline points at a 2.8 mm female instead. I have not measured a COM-13014 with calipers. Could you measure the tab width and thickness on one you have in stock and confirm whether a 2.8 mm (#110) female quick disconnect is the correct mate, and whether the 3.2 mm line on the product page should be corrected?
We should be able to check on Thursday when we have a person on-site, hang tight!
@TS-Russell Thank you! I appreciate it!
Looks like 3.2mm :slight_smile:
