Correct 20-pin 0.5 pitch extension cable for Raspberry Pi 5
I am currently using the Raspberry pi 5 with an Arducam 12MP quad-cam HAT. All ribbon cables are 22 pin 0.5 pitch flex from what I can tell.
This js what it comes with: https://www.uctronics.com/150mm-22pin-to-22pin-camera-cable-0.5mm-pitch-interface.html
Since it only came with 15 cm ribbon I would like to to extend all four cameras to 30 cm.
I was hoping someone could help me find an extension ribbon that works.
You can get extension connectors that combine 2 cables but it’s probably cheaper to get a longer cable.
These might work for you and they are less than a dollar per cable!
FFC FPC Flat Flexible Cable, 22 Pin 0.5mm Pitch 300mm Long (A Type) for LCD 3D Printer Camera DVD TV Laptop Audio Pack of 10 | Harfington FFC FPC Flat Flexible Cable, 22 Pin 0.5mm Pitch 300mm Long (A Type) for LCD 3D Printer Camera DVD TV Laptop Audio Pack of 10 | Harfington
