Defective Order #000222775
Dear Support Team,
I’m writing to report an issue with two products I recently purchased that do not appear to be functioning as expected.
The items are:
  • MyoWare 2 Muscle Sensor (SKU: DEV-27924)
  • Disposable Surface EMG/ECG/EKG Electrodes – 24mm (10 pack) (SKU: SEN-1296)
After setting up the sensor according to the provided documentation, I have been unable to obtain any reliable or consistent signal output. I’ve tried multiple configurations and ensured that all connections are secure. I also tested with fresh electrodes from the pack, but the issue persists, which makes me suspect the sensor or electrodes may be defective.
To troubleshoot, I have:
  • Verified wiring and power supply
  • Tested with multiple electrodes
  • Ensured proper placement and skin preparation
Despite these steps, the sensor does not respond as expected.
Could you please advise on next steps? I would appreciate guidance on troubleshooting, and if necessary, information on a replacement or refund.
Thank you for your assistance. I look forward to your response.
Kind regards,
Can you share a photo of the setup while in-use? You don’t need to actually place the sticky electrodes, you can just set it where they are/were during
How is the unit being powered? What are you seeing @ the serial output?
Hello
Please find attached pictures
Please share photos that have the requested details…it sitting in a box unpowered with a mess of wires blocking its own view with no relevant body/muscle placement means it could literally be anything…wiring. placement, power, software…
Hello
Please find attached the pictures of the unit attached
