Facet returning inconsistent elevations
You might not want to bother with this, but here’s a simple way to verify the precision (repeatability) of the System, that everyone can perform:
Install the Facet on a position/point that can be repeated.
Store RTK Fixed solutions only in SW Maps. Do this many times, spread-out over time. The idea is you want different Satellite geometry, different atmospheric conditions, etc.
Export the Points to a spreadsheet with UTM turned ON.
UTM allows you to quickly subtract the smallest value from the entire data set (X, Y, and Z individually).
You can easily see the range of values, because all you are left with are a couple of centimeters over the entire data set (hopefully).
Here’s a link, for iOS SW Maps.
