SKU: GPS-23088 & SKU: GPS-23748
I want to enquire about a few points below:
- Is both the components mentioned above compatible with each other? How can I use both of them together? For RTK base station how to setup? Can I get an integration guide to understand more about it?
- What are the max sample rates available? In Data sheet of mozaic i can see 100HZ but there is a slight confusion regarding single and dual antenna? what are they? For the above selected components what sample rates I will get with RTK?
- SKU: 23088 I will use in my UAV application in air so what antenna do you suggest me for that?
Dear Sparkfun Team, kindly assist me with the queries so I can proceed accordingly.
