Dear SparkFun Team,
Thank you for your support.
I have a question regarding part GPS-28019.
The customer is using this module in a vehicle together with RTK-compatible antennas. The same antennas have already been used successfully with other RTK-GNSS products, so there is sufficient evidence that the antenna setup itself is valid.
The application is to record the vehicle’s position and heading with high accuracy.
The module is operating, but the behavior is unstable. Under normal conditions, it outputs latitude and longitude correctly. However, for an unknown reason, the position output occasionally becomes all zeros during operation. When this occurs, disconnecting one of the two antennas (Antenna 2, the secondary antenna on the board) immediately restores the output and the module resumes normal operation.
The customer owns another unit of the same product and has not observed this behavior on that unit. The issue appears to be limited to a single device.
The product was purchased in September, and the abnormal behavior was noticed in October, approximately one month later. Since this was the customer’s second GPS-28019 unit and the two devices were not used simultaneously, they were initially unaware that there was any difference between them. As a result, it is difficult to determine exactly when the issue first started occurring. The problem was only discovered after investigating occasional missing position records.
Could you please advise whether this behavior is a known issue, and whether there are any recommended diagnostic checks or troubleshooting steps? In particular, do you have any concerns regarding the Antenna 2 input or related circuitry?
Thank you for your assistance.
Kind regards,
Takashi
T4961837
