Help with equipment acquisition/configuration
We are currently using the NEO-M8U successfully, it meets our demands well, however we wanted to test something more precise here at the company, so we are considering purchasing the ZED-F9P, to use the RTK, what are the ways I can integrate it with an RTK? Should I have a base nearby transmitting data? Can we use Point Perfect from Ublox? If so, which module do I need to add? how this is done.
Thank you in advance.
You’d just follow along with our guide GPS-RTK2 Hookup Guide - SparkFun Learn
If there isn’t a correction source within 10km, you can either create your own base with another unit or use a PPP service like PointPerfect Flex if you have coverage in your area and use a slightly different board, SparkFun GNSS Combo Breakout - ZED-F9P, NEO-D9S (Qwiic) - SparkFun Electronics
