need help with coding here are the components etc (servos control trim tabs)
Arduino uno R4 minima controlling 2 hitec HS-125mg servos (servo’s have 119 degrees of ratation at 900-2100 pulse width with 2 pushbuttons for each servo, manual increments on button hold emergency reset to center of travel when both buttons are pressed servo’s are powered by a 6a-BEC
