LED tactile button
How do your LED tactile buttons work? Does the LED light up when the user presses the button? Or does it remain ON when the button is not pressed?
The LED and button are completely independent of one another so the LED does whatever you program in your application.
As above; the LED is controlled by the two wires/legs that come out its opposite sides (from the white plastic) and the switch is controlled by the two coming out its front (black plastic)
It will be better if you add a hook up guide for this product.
Button and Switch Basics
Light-Emitting Diodes (LEDs)
I understand these. I just needed to know which pin of the LED tactile button is for what purpose. This matter wasn’t clear to me from the product description. Thank you.
