LG580P Configuration Issue
Can anyone explain why my LG580P refuses to allow me to select the signals? I have the receiver set to signal group 0 which disables the secondary port and allows GLONASS to be enabled. It takes this properly as I can no longer set signals on the second antenna and it now allows GLONASS to be enabled. But no matter what signals I enable PQTMCFGSIGNAL it is always GPS,Gal.,BDS even though it’s accepting the commands and a Query confirms what I’ve set as enabled.
In this example you can see in the terminal I’ve changed the module to ONLY Galileo, saved, hot reset, but it’s still receiving all signal despite a Query showing everything is disabled except Galileo.
Am I missing something here?
Additionally PQTMCFGCNST is set to only galileo in this example
and firmware is as follows. I notice there was a new firmware on this forum posted about a year ago which was a beta firmware which I’m not comfortable using in production. Is there a newer full release since then?
Not the correct group…choose group 2 instead
$PQTMCFGSIGGRP,R*3C default is 1 set to 2 → $PQTMCFGSIGGRP,W,2*27
then save & reboot, once done respect the hierarchy >>The priority of GNSS configuration: PQTMCFGCNST > PQTMCFGSIGNAL > PQTMCFGSAT <<
take note of the default values and save them into a folder…
e.g. the lg290p has
$PQTMCFGCNST,R*2E       $PQTMCFGCNST,OK,1,1,1,1,1,1*78
$PQTMCFGSIGNAL,R*3A   $PQTMCFGSIGNAL,OK,07,03,0F,3F,0F,01*1C
$PQTMCFGSAT,R,2,1*61       $PQTMCFGSAT,OK,2,01,00003FFF*5E
$PQTMCFGSAT,R,2,2*62       $PQTMCFGSAT,OK,2,02,00003FFF*5D
if not, set to:
$PQTMCFGSAT,W,2,1,00003FFF*3D
$PQTMCFGSAT,W,2,2,00003FFF*3E
take note also of $PQTMCFGSIGNAL2,R*08
$PQTMCFGSIGNAL2,OK,07,03,0F,3F,07,01*5F
