Lilypad Vibemotor Datasheet - updated or not?
: https://cdn.sparkfun.com/assets/4/a/9/8/2/310-101_datasheet.pdf
https://www.pressabout.com/precision-microdrives-revises-381284/
Hello, I hope you’re all doing well!
I was wondering if the current datasheet on the Lilypad VibeBoard from 2008 is accurate or if the newer version of this motor from precision-microdrives 2013 is what is being used. The current model has .8g vibration amplitude.
However the manufacturer of the motor stated in a press release in 2013 (linked above) that the same motor (310-101) had been upgraded to 1.2g of vibration amplitude. When I went to look for the model on precision mircodrives website however - I could not find this model. If anyone has any insight as to which version of the motor is being used and sold I would greatly appreciate it!
It looks like we use this one now https://cdn.sparkfun.com/datasheets/Robotics/B1034.FL45-00-015.pdf - I’ll get the datasheet swapped out
