I’ve used logomatics for decades but have not had my current problem before. I have a robot with three micros (two Mega2650 and a Teensy4.0), each connected to a different logomatic, all operating in Mode 0. Originally, there was just one Mega. It logs fine, then and now. However, the other logos don’t log at all. I’ve checked the connections, the baud rates, I’ve formatted the microSD cards in FAT 16, tried alternate SD cards, and installed a new logomatic, all without success. Sometimes one of the logos will flash a buffer led and the card will indicate a file with 1 KB of data, but there is nothing on the card. I can’t think of anything else to try.
Help and thanks,
John-
Odd - How are they powered? Are all 3 using the same power source? Does swapping the working one to one of the non-working locations enable that location to log?
Thanks for the reply.
Yes, they are all basically powered by the same, system 5v supply, indirectly through the Mega sensor shields, not the Mega 5v supply. I have not tried swapping, although I did replace one non-functioning logo with a brand new one. I’ll try swapping.
John-
Got the logomatics to work; not sure what did the trick. I swapped the UART input from a non-working logo to a working one. That confirmed that the Mega was outputting data and the connection to the logo was good. So, I discarded the non-working logo and replaced it with a working one, and everything is fine. I am hesitant to blaming hardware since that isn’t usually the problem.
John-
