M7E Hecto – what happens to the supply rails with USB-C (data) and external VIN connected at the same time?
Hi all,
I’m using a SparkFun Simultaneous RFID Reader – M7E Hecto with an Orange Pi 5 Pro as host, over the onboard USB-C (CH340C). Reading continuously at up to 27 dBm can draw more than 700 mA, so I’d like to power the reader from a dedicated external 5 V supply on the VIN header pin and use USB-C for data only.
According to the hookup guide, VIN SEL is closed by default and nets V_USB, VIN and VCC together. I’m trying to understand how the board behaves electrically if I leave the jumper as shipped and connect both at once: USB-C to the host, plus the external 5 V supply on VIN.
My questions:
  1. Parallel supplies: With VIN SEL closed, is the host’s VBUS tied directly to VIN, with no diode, ideal diode or power-mux in between? If so, which source supplies the M7E’s current: whichever is at the higher voltage, or is it shared?
  2. Back-feeding the host: If my external supply sits slightly above the host’s VBUS (e.g. 5.1 V vs 5.0 V), will current flow back into the host’s USB port? Has anyone seen problems from this, such as the port’s current limiter tripping, the host browning out, or the USB port getting damaged?
  3. The opposite case: If the host’s VBUS is the higher one, will the M7E end up pulling its >700 mA load from the USB port anyway, defeating the purpose of the external supply?
  4. Power sequencing: What happens if the external supply is on while the host is off? Does the M7E back-power the host through USB? And the other way round: host on, external supply off, does VBUS push voltage back into the supply’s output?
  5. Recommended setup: For “USB = data only, VIN = power”, which do you recommend: cutting the V_USB leg of VIN SEL (and if so, which pad), or using a data-only USB cable with VBUS removed and leaving the jumper closed? Either way, will the CH340C stay powered from VIN and enumerate normally?
Thanks in advance!
  1. Usually the higher-powered one; you’d generally want to open the VIN SEL jumper (cutting the trace between V_USB and VIN) to isolate those 2 circuits https://cdn.sparkfun.com/assets/9/4/b/c/6/SparkFun_Simultaneous_RFID_Reader_M7E.pdf
    The diode in the schematic doesn’t separate VCC and V_USB (it does separate V_USB from VIN when the jumper is disconnected)
  2. Yes, that is a concern with the jumper unmodified (the higher voltage will usually become the supply and try to back-feed the other)
  3. I believe so
  4. Refer to the schematic linked above…the short answer is yes (again, if the jumper is unmodified)
  5. It’s easier/simpler to cut the jumper pad trace, separate V_USB and VIN (this can help prevent accidentally using the wrong cable later and causing issues). Yes, it will work normally after (VIN and VCC are still netted together, CH340C will get power from the usb cable and the RFID module will use VIN)
You will also want to tie the GROUND of both power systems together (connect OrangePi GND to M7E GND, connect the VIN supply’s GND to the M7E GND)
Thanks a lot, that clears it up! I’ll cut the V_USB–VIN trace on VIN SEL and tie all grounds together. Much appreciated.
Cutting the V_USB–VIN trace is the right call before you tie the grounds together, since that’s what actually stops the back-feed between the two supplies. One thing worth checking after the cut: confirm with a meter that VIN SEL is truly open, because a partially severed trace can still leak and you won’t notice until the OrangePi is connected and something behaves oddly. Also verify the CH340C still enumerates over USB-C once VIN is on its own supply, as that’s the quickest way to confirm the isolation worked as intended.
Thanks, good points! I’ll check the cut with the meter on resistance (expecting OL) instead of relying on the continuity beep, so a partial cut doesn’t slip through.
One nuance on the CH340C check: since it’s powered from USB either way, it would enumerate whether the trace is cut or not, so I don’t think it proves the isolation by itself. To confirm that, I’ll do a quick voltage check before tying the grounds: with only USB-C connected, VIN should read 0 V, and with only the VIN supply on, VBUS should read 0 V.
