Micro:bit and 1.3 in display
Just got a micro:bit module and a 1.3 inch display connected by quiic connector module. The example python code loads, but run time error when encountering the import qwiic_oled line. I used MU 1.2.0’s built in package installer to install qwiic_oled_base package, but the error remains. Any assistance would be appreciated.
That OLED uses this library “Qwiic OLED” library, which is not the same as qwiic_oled_base…be sure to grab the right’n
Also, the library is CPython (Raspberry Pi, Linux, etc.). It depends on qwiic_i2c, which needs a full Python with a Linux-style I2C stack (micro:bit runs MicroPython which can’t use CPython packages)
Mu’s package installer in Python 3 mode installs packages onto your computer’s Python, not the micro:bit. This is why installing qwiic_oled_base doesn’t go anywhere
Options :slight_smile:
  1. MakeCode (makecode.microbit.org): if you just want text and graphics on the display quickly, look for an OLED extension under Extensions. Many SSD1306/SH110x-based displays have one, and it handles I2C for you. Check that it supports your display’s chip. You can also make one
  2. MicroPython with a small driver: write or copy a lightweight driver for your display’s controller (SSD1306) that talks to the micro:bit’s i2c object directly. Save it as a .py module on the micro:bit using Mu’s Files button, then import it
  3. A different board: if you want to use the Python examples as written, run them on a Raspberry Pi or use a CircuitPython board with our CircuitPython libraries
The point about Mu’s package installer being for your computer’s Python 3 rather than the micro:bit is the key detail here. That explains why installing qwiic_oled_base changes nothing on the board itself. Worth checking which controller is actually on the 1.3 inch display before trying an SSD1306 driver, since a mismatch means the I2C calls will go out but nothing useful will show up. The MakeCode extension route also seems like the lowest-friction way to confirm the hardware works before writing a driver. Does the display’s chip match SSD1306?
