MLX90640 110° (SEN-14843) holds SDA low, never detected at 0x33
Hi, my SparkFun IR Array Breakout 110° FOV (MLX90640, SEN-14843) is never detected, and it blocks the I2C bus as soon as it’s connected.
Setup: Raspberry Pi 5 with a SparkFun Qwiic Mux (TCA9548A).
What I tested:
- The board’s PWR LED lights, so it receives power.
- The Mux works: it responds at 0x70 and all channels switch correctly when nothing is connected.
- As soon as the Mux channel with the MLX90640 is enabled, SDA is pulled to ground and stays low until power is removed. Nothing responds at 0x33.
- Same result on two different Mux channels (0 and 1), with two different Qwiic cables, and on both of the board’s Qwiic connectors.
- Same result with the sensor wired directly to the Pi’s I2C pins (no Mux): SDA is low from power-up and nothing is detected.
- The Pi’s I2C bus and pull-ups are fine; other devices on the bus work normally.
During initial setup there may have been a wiring error on the Pi header; I’m not certain whether that caused the failure.
Is there anything else I should try, or can this be handled as a return? Thanks!
Sometimes on those the soldering can short on the backside of the board (where the pins poke through)
If you have a soldering iron handy the easiest fix is to follow this thread and re-solder the unit with a small non-conductive spacer of some kind (they used a small pad)
Thanks for the quick reply and the tip! I checked the back of the board and can’t see any obvious solder bridges between the pins, but I understand the short may be too small to see or between a pin and the board.
Unfortunately I don’t have a soldering iron or soldering experience, and I’d rather not risk damaging the sensor trying to rework it myself. Since this sounds like a known assembly issue with this board, would SparkFun be able to replace it or process a return? I’m happy to send photos of the board or any other details you need.
@TS-Russell Do you have any update on this?
Was it purchased from us? If so head over to Return Policy - SparkFun Electronics (contact vendor if purchased elsewhere) and we’ll get ya squared away with a replacement
