Mosaic X5 Baud Rate
I have two RTK Mosaic X5 kits. I have one set up as a base station and one as a rover. I can get a RTK fix when I have them hardwired together but if I add a serial radio there is no rtk data received on the rover even though the radio show data transferred. I have tried a few different baud rates. I then used Tera Term to watch the ouput data stream from the base station. I have them set to the same baud rates but get garbage data. It is as if the data ouput from the base station is a different baud rate than it says it it.
You’ve got a classic baud rate mismatch somewhere:
  • The base unit needs to be outputting data at the baud rate that the base’s radio is expecting to receive it.
  • Similarly the rover needs to be setup to receive data at the baud rate that the rover’s radio is sending it out its UART.
Double check all your settings, especially the radios.
Adding to @sparky’s answer: “garbage” in Tera Term doesn’t by itself mean a wrong baud rate. RTCM v3 is a binary protocol, so a correct correction stream always looks like random characters in a text terminal. A better check is to look for the RTCM sync byte 0xD3 at the start of each message (Tera Term can’t show this; RealTerm in hex mode or a logic analyser can), or to feed the stream into RTKLIB’s strsvr/rtkplot and see whether it decodes.
When it works hard-wired but not through the radios, these are the usual causes:
  1. Port settings on both mosaics match their radios. Same baud rate, 8N1, and flow control off, unless the radios actually use RTS/CTS. On the base, the radio’s COM port should be set to output RTCMv3. On the rover, the radio’s COM port should be set to accept RTCMv3 as input. It’s easy to leave the rover’s input on “auto” or on a different COM port from the one the radio is wired to.
  2. TX/RX wiring. Hard-wired you may have used a crossover, while the radio needs base TX → radio RX, and radio TX → rover RX.
  3. The radio’s air data rate vs the size of the RTCM stream. This one catches a lot of people. MSM7 with four constellations at 1 Hz can be well over 1 kB/s, which is more than many serial radios carry over the air at their default settings. The radio then drops or truncates messages, and the rover sees nothing usable even though the “data” LEDs blink. Try:
    • MSM4 instead of MSM7;
    • fewer constellations (for example GPS + Galileo first);
    • 1005 only every 5–10 s;
    • a higher air rate on the radios, if their range allows.
  4. Serial baud above the radio’s own UART limit. Some radios take 57600 or 115200 on the serial side but buffer badly. 57600 is usually a safe test value.
A quick way to tell which side is the problem: put the radio pair between a PC and the rover. Send a known-good RTCM file or NTRIP stream from the PC (RTKLIB strsvr) and see whether the rover gets a fix. If it does, the problem is on the base’s output side.
(Disclosure: I work at Eview GNSS; we build Septentrio-based receivers, including mosaic-X5 based ones.)
