I recently received a brand-new XRP robot (Batch #184311), but I am unable to establish a USB connection between the robot and my Chromebook.
The controller powers on, and the red LED illuminates when connected through USB-C, even with the battery pack disconnected. However, the Chromebook does not recognize the robot.
I have tried:
Multiple USB-C cables.
Different USB connection attempts.
Holding BOOT while pressing and releasing RESET to enter bootloader mode.
Checking the Chromebook’s USB functionality with other devices.
Despite these attempts, the RP2350 drive never appears, and the computer does not recognize the controller.
Since this is a brand-new unit, I would appreciate assistance determining whether the controller is defective or whether there is another setup procedure specific to this hardware revision.
Thank you for your assistance.
There is not a specific procedure :-/
Are you on a school network? Sometimes permissions can be locked for USB (though confirming comms with other devices mostly rules this out)
Do you happen to have a alternate PC/laptop you can test with that isn’t a chromebook?
The red LED coming on with only USB-C and no battery pack suggests the board is getting power, so the cable and port are likely fine. On a managed Chromebook, USB data access can be restricted by policy even if other devices work, and the drive may simply be blocked. Testing on a non-Chromebook machine, as suggested, would separate a policy issue from a dead controller. If the RP2350 drive still never shows there, and the BOOT/RESET sequence was done correctly, I’d treat it as a hardware fault and contact the supplier for a replacement under the new-unit warranty.
Yes, I am using a school Chromebook. We received two new XRPs and only one of them will not connect so I don’t think the computers are the problem.
Ah, gotcha. In that case try the steps here Unable to Connect XRP to XRP Code Editor - #10 by SparkFro and if that doesn’t get it going:
Was it purchased from us? If so head over to Return Policy - SparkFun Electronics (contact vendor if purchased elsewhere) and we’ll get ya squared away
