OBD-II UART 5v --> 3.3v
I’m looking for guidance with a project I am working on. I want to use the Spark Fun OBD-II UART board to read live data from the ECU and store this data in the Texas Instruments EK-TM4C123GXL. Then I want to output this data to a touch screen LCD using SPI.
One potential issue I may run into is the 5v UART on the Spark fun board and the 3.3v UART on the Texas Instruments board. I looked into potentially using the SparkFun Logic Level Converter - Bi-Directional to handle that conversion but I am worried about latency issues.
Can anyone from Spark Fun confirm whether or not this would work? And whether or not the logic level converter slows down communications at all?
To give more context I want to ask the ECU to provide 3 data pieces in continuous loop and update the LCD as fast as it can. to display vehicle speed, RPM, and ECT. I know that the Spark Fun OBD-II UART board only outputs hex values but I can use the Texas Instruments board to decode them into real values before outputting to the LCD.
Can’t guarantee it under every situation but I don’t believe latency through the logic level converter is going to be an issue for you.
I don’t recall how fast I’ve pushed data through one of these in the past but I’ve never had any issues using them with UART, I2C and maybe (don’t exactly remember) SPI.
Worst case, you could swap out the bi directional logic level converter for something else later if it does give you troube.
