Op Amp
I’ve got this op amp breakout SparkFun OpAmp Breakout - LMV358 - SparkFun Electronics
I’ve hooked it up to a piezo pickup used to record vibrations signals. I find that the output signals are a little too large for me. So I’m adding a voltage divider step after the amplification
As I understand voltage dividers really only depend on the ratio of the resistances used. So I was thinking of just adding some low resistance resistors to do this. Is this potentially a bad idea? Is there any reason to use higher resistances?
Usually, an acceptable choice is to match the total resistance of the divider to the impedance of the signal source. That would probably be quite high (megohms) for a piezo source, in which case you may need to comprise and consider the op amp input bias current (typically 11 nA for that board, according to the data sheet provided by Sparkfun).
Hint: when posting questions on a technical forum, the more information you provide, the more likely the answers will be relevant.
