OpenLog Artemis Battery power & reset
Hello again cjlyth,
I forgot to thank you for the photos.
If you want to, you can connect your power switch to the PSWC breakout pads instead of breaking into the LiPo battery cable.
When the PSWC switch is closed, the OLA is powered down. The advantage of doing it this way is that you can still recharge the battery while the OLA is powered down.
