Optoisolator with Darlington Driver - 1 Channel Help
njr27:
I purchased a few more of these and tested them just like you showed me. They work!
Thank you for all of your help and patience.
How do you make this forum topic “Solved”?
Glad it all worked out ! Did you get it to work in your application yet ? It should.
As for marking solved … I don’t there is a way. I guess you could edit the title and add “- now solved”, though it’s not necessary.
I will try it in my application after I do some more testing. I need to make sure that everything works on the breadboard before I start soldering.
