After many hours of troubleshooting, almost a year off where I didn’t think it would work, I’ve finally (with the help of a few threads and a number of other users on this forum) make my Postcards talk to each other using Sparkfun LoRa Radios. Here is the complete how to:
What to buy:
Sparkfun Postcard, LoRa Radios, Antenna, cable to connect Postcard to LoRa and other asst components (USBC, antenna cable, etc)
Setup:
You need to setup your system in the following way
You MUST power your Postcard and LoRa independently through their USBC connections. If you try and power the LoRa through the Postcard, the Postcard will brownout
However, you need to have the ground of the Postcard connected to the ground of the LoRa
For the Base Station, you need to connect the Tx on the PostCard to the Rx on the LoRa
For the Rover, you need to connect the Rx on the Postcard to the Tx on the LoRa
So, in total, you have 2 wires connecting each Postcard to is LoRa and they can’t be interchanged. Wiring it this way eliminates data coming back from the Rover which is what you want
Scratch out the jumper - JP3 - on the LoRa boards (see this thread for more details on why) and check there is no continuity using a multimeter - it is label RS on the board and is here:
Configuration:
Postcards:
Update your postcards to the latest RTK Everywhere firmware here. Mine was v3.4
Update your LG290P to the latest firmware here. I used V2.01 (I didn’t bother to update to v2.02)
Base Settings are here:
Base Postcard Configuration.pdf (145.0 KB)
Rover Settings are here:
Rover Postcard Setup.pdf (135.9 KB)
LoRa’s:
As noted in the post here and the post on the review of the LoRa’s (and likely other posts), the LoRa’s need to be run in Broadcast mode and not Point 2 Point.
As per the post, I uploaded the firmware found here
On each set AT-Airspeed=19200 (this sets about 4 other settings and will show 0)
Change the Base LoRa to these settings:
Base LoRa Settings.pdf (123.2 KB)
Change the Rover LoRa to these settings:
Rover LoRa Settings.pdf (122.4 KB)
Testing:
- Connect a good power source to each LoRa and Postcard
- Ensure that you are outside
- you may want to turn on some periodic messages on your postcards to see what is happening
- Keep your LoRa antennas a couple meters apart
Operation:
- Turn off any testing periodic messages
- You may want to turn up the power on the LoRa’s to 30
And that’s it. The LoRa’s don’t have the bandwidth for the full quadband capabilities of the Postcard but offer reasonable capability for a decent price. I have yet to try them in the field but will do so in the coming months to see their performance. I was typically seeing ages of under 3 sec and no more than 30 sec during testing.
I also have a custom 3d printed enclosure to house the Postcard and the LoRa if anyone is interested in making that box
