Prototyping and I2C
The clipping of the header pins is a great idea, I never thought of that! Thank you.
I’m not sure I understand what you mean with how to daisy chain the SCL and SDA lines. Would you mind explaining it a little more or pointing me in the direction of a tutorial/image?
I will have one master device (Feather M0) hooked up to six slave devices (Temp+Humidity, GPS, UV, Air Quality, Barometric Pressure+Altitude, and finally a TFT screen with a joystick and two buttons.
Thanks again!
