I have two MyoWare (DEV-27924) EMG sensors that I want to feed directly into Raspberry Pi but the pi doesn’t have analog input. Is the process just adding an ADC? If this is for real-time data processing is 12 bit at 3300 Hz ok or is it better to do 16 bit at 860 Hz?
Yep, you’ll need an ADC if you’re using a Pi - in this scenario I’d probably go with the 12-bit (currently sold out)…while the 16-bit offers 16x more signal resolution I think the temporal resolution/sample speed is worth more for most EMG stuff
Do note that the MyoWare has three different analog outputs: RAW, RECT, and ENV. They serve different purposes:
RAW — best for detailed EMG, analysis preserves the amplified EMG waveform. Choose this if you want to analyze waveform shape, frequency content, or muscle activation in detail.
RECT — rectified EMG, makes the waveform unidirectional, useful for analyzing signal magnitude without processing negative excursions yourself.
ENV — smoothed muscle activity, best for simpler applications such as detecting a flex, triggering an action, or estimating muscle activation strength. Its envelope detector has a 3.6 Hz cutoff, so it has much less fast-changing detail.
