this library called out? SparkFun_UHF_RFID_Reader.h
yep you need to install that :
see hookup guide : Library Setup - SparkFun Simultaneous RFID Reader - M7E Hookup Guide
Menu ArduinoIDE : Tools⌠Manage libraries
âinstall the library through the Arduino Library Manager by searching for âSparkFun Simultaneous RFIDâ and selecting the latest versionâ
got a lot of errors when i included the library, this is the report from âverifyâ
In file included from C:\Users\Bolto\Documents\Arduino\8danseasyrelay\Sketch_from_sparkfun\Sketch_from_sparkfun.ino:16:0:
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:81:3: error: redeclaration of âThingMagic_M6E_NANOâ
ThingMagic_M6E_NANO,
In file included from C:\Users\Bolto\Documents\Arduino\8danseasyrelay\Sketch_from_sparkfun\Sketch_from_sparkfun.ino:1:0:
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:81:3: note: previous declaration âThingMagic_Module_t ThingMagic_M6E_NANOâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:82:3: error: redeclaration of âThingMagic_M7E_HECTOâ
ThingMagic_M7E_HECTO,
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:82:3: note: previous declaration âThingMagic_Module_t ThingMagic_M7E_HECTOâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:83:3: error: conflicting declaration âtypedef enum ThingMagic_Module_t ThingMagic_Module_tâ
} ThingMagic_Module_t;
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:83:3: note: previous declaration as âtypedef enum ThingMagic_Module_t ThingMagic_Module_tâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:87:30: error: redeclaration of âThingMagic_PinMode_INPUTâ
ThingMagic_PinMode_INPUT = 0,
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:87:3: note: previous declaration âThingMagic_PinMode_t ThingMagic_PinMode_INPUTâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:88:31: error: redeclaration of âThingMagic_PinMode_OUTPUTâ
ThingMagic_PinMode_OUTPUT = 1
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:88:3: note: previous declaration âThingMagic_PinMode_t ThingMagic_PinMode_OUTPUTâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:89:3: error: conflicting declaration âtypedef enum ThingMagic_PinMode_t ThingMagic_PinMode_tâ
} ThingMagic_PinMode_t;
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:89:3: note: previous declaration as âtypedef enum ThingMagic_PinMode_t ThingMagic_PinMode_tâ
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:91:7: error: redefinition of âclass RFIDâ
class RFID
C:\Users\Bolto\Documents\Arduino\libraries\SparkFun_Simultaneous_RFID_Tag_Reader_Library\src/SparkFun_UHF_RFID_Reader.h:91:7: note: previous definition of âclass RFIDâ
class RFID
exit status 1
Compilation error: exit status 1
before i included the library, everything verified fine, but there was no response on the LED
and to be clear, i went to sketch > include library > spark fun library. It may have included ALL of the libraries which is why the M6E Nano is coming in. i am going to start over
latest wiring and reloaded sketch. still no response. I did notice areound line 90 that is asking for a manual input to start scanning. not sure if that is really asking for an input, which i cant do
Serial.println(F(âPress a key to begin scanning for tags.â));
while (!Serial.available()); //Wait for user to send a character
Serial.read(); //Throw away the userâs character
Do you still get an error compiling uploading ?
Is the M&E power led ON?
What do you seen when you connect USB to the serial monitor of the ArduinoIDE ? (make sure the later is set to 115200 baudrate)
You just need to press when asked (later you can remove this when needed)
Is the switch set to serial on the M7E ?
error on uploading - not really, however once i get it loaded and i try again, it gives me an error around not having a specified port
M7E power - yes it is getting power from the arduino
serial monitor - is that the RX/TX lights? if so, one quick yellow flash on TX then nothing. - that was a good catch on the baud rate since the 115200 was not active in the code.
pressing the button - does this require the button on pin 8? is the the input requested? I do not have the button installed
switch set to serial - i think so. When I go through the universal reader it shows serial.
you should keep the USB connected and start the serial monitor in the arduinoIDE (looking glass top right end)
What messages do you get after starting / pressing reset on the MCU board ?
The SWITCH on the M7E can be set to USB or SER. This must be set to SERIAL
The manual switch does not need to be installed
M7E was on USB moved to serial.
Message from monitor - Module failed to respond. Please check wiring.
wait. wire in wrong spot. corrected and now it read -
Press a key to begin scanning for tags - after pressing key
High return loss, check antenna - over and over
and with a tag - Bad CRC
question - since this is hardware serial, does this need to be commented out? It looks like most of this is software serial:
#include <SoftwareSerial.h>
SoftwareSerial softSerial(2, 3); //RX, TX
and if it is correct with software serial - should the RX be in pin 2 and TX in 3?
good progressâŚ
You are communicating with Software Serial to the M7E. So you should keep that in place.
The communication with the m7E works, else you get âcheck wiringâ. As such RX and TX are connected correctly. NO CHANGE needed
I suspect your errors are because of power OR speed. in top of sketch it states
#define rfidBaud 38400 reduce that from 38400 to 19200 for test
What power supply do you use ?
Make sure the VCC and GND wires are good connected
Any changes made to the M7E board for the antenna ?
Maybe some pictures.
as i reduce the baud rate on the rfid reader, do i reduce the baud rate on the arduino the same?
and i am powering from the computer USB. I checked the connections and i am getting good connectivity to RX, TX, VCC and ground.
i reduced the baud to 19200. same error, but i did notice that only the TX light was flashing on the arduino
reduced both the reader and arduino to 19200 and same error, and TX light flashing red
