I previously posted about selecting a GNSS receiver for our Smart Tire project. Since then, we have narrowed down the requirements and are now considering an RTK-based setup for both precise vehicle positioning and timing synchronization with an NI DAQ.
Our goal is to locate road defects as accurately as possible while also using a PPS timing signal to synchronize the GNSS data with accelerometer and strain measurements.
For anyone in the Chattanooga/Tennessee area, what RTK/NTRIP correction service or network do you use or recommend for centimeter-level positioning?
Operating your own Base might be your best path. A Station with a Mosiac X5, paired with a X5 Rover gives you ultimate control.
What System and Reference Frame will the end user want/need? I assume the target is the Municipality?
TN DOT is $50/month. They currently use NAD83(2011) but will be transitioning to NATRF2022 (required by law for the State Agency).
Point Perfect is $15/month. It’s Reference frame is ITRF2020 (Note: NATRF2022 uses ITRF2020 as its mathematical basis).
If you are building a professional rig, I think the Mosaic X5 is the best choice for your application. You can always start with an X5 Rover and PointPerfect. If that combo doesn’t suit your needs, you can add an X5 Base Station later and really drill down into accuracy for your project.
If this is a university project with a help-the-public goal, I suggest contacting TN DOT and asking for free service and agreeing to send them all the data. (If you are a company developing a product rather than hobbyist/university, it would have been nice to say that.)
