I need to remove 12V DC male power supply plug, 5.5mm 2.1mm from power supply that has protruding positive center pin and replace it with a male plug that that will slide over the 5.5mm 2.5mm positive center pin jack that will receive the power. Is this the correct part or might you have another recommendation?
The wording is throwing me a bit (to be clear, you need something to interface with a Female barrel jack?)
Yes if you are replacing Male with Male and 5.5mm outside x 2.1mm center-positive male barrel jack is the right size
I don’t see what you need at sparkfun, amazon has what you’re looking for.
