SNM022A-12 Full dimensions and capabilites
Not a regular forum user, forgive me if I’m in the wrong spot. I don’t know how to navigate these things.
I’m looking for complete details on SNM022A-12. I want to integrate it into a product, but the PDF does not have enough details. Can this be used in place of a bearing? What is its internal bearing ratings? What are the actual dimensions and tolerances, so I can design my parts around it? EDIT: Can it continually reciprocate instead of full turns?
Thank you,
Thomas
Can this be used in place of a bearing? - That’ll depend on the forces involved in your apparatus…for small loads, sure
*What is its internal bearing ratings? * - PDF says 2kg radial, 0.5kg axial
What are the actual dimensions and tolerances, so I can design my parts around it? - * 22mm Diameter x 26.5mm Length w/ 44.5mm Diameter Flange (from product page)
Hi TS-Russel, Thank you, I’d missed the 2kg radial, that’s a good number for me. However the dimensions are not clear enough, I need tolerances to fit my parts to it. The dims on the PDF are unintelligible. What are the mounting Thru Hole sizes? Hole pattern diameter? Rotor side diameters and tolerances? rotor length? Can I get a STEP file so I don’t have to rely on my estimates?
Found it
The PDF on our site does look degraded; we’ll get it updated to that one ASAP - thanks for the link!
