Sparkfun Artemis Open log - on board IMU sensors non responsive
Confirmed, I am using OpenLog_Artemis-V10-v20.bin as the version when I wrote the original post. I have reloaded it to make sure and the problem persists - and it does.
The conclusion of the reload dialog follows:
Sending frame #176, length: 880
Got frame request
Upload complete!
Nominal bootload 9732.98 bytes/sec
Chappelled, I think your unit might be defective.
If you could file a return ticket we will get you taken care of: https://www.sparkfun.com/returns
Is there any other fix until now?
I tried even the never .bin version (OpenLog_Artemis-V10-v25.bin) but get the same error
Artemis OpenLog v2.0
Logging to: dataLog00026.TXT
Finding the next available log file.
This could take a long time if the SD card contains many existing log files.
Logging to: serialLog00000.TXT
ICM-20948 failed to init.
SD card online
Data logging online
Serial logging online
IMU offline
Identifying Qwiic Muxes…
Identifying Qwiic Devices…
No Qwiic devices detected
rtcDate,rtcTime,output_Hz,
01/01/2000,00:22:58.76,0.0,
01/01/2000,00:22:58.86,20.0,
01/01/2000,00:22:58.96,15.0,
01/01/2000,00:22:59.06,13.333,
01/01/2000,00:22:59.16,12.500,
Hi @ mutzi04,
There are two versions of the OpenLog Artemis: one with IMU, and one without. Please check if yours has the IMU:
https://learn.sparkfun.com/tutorials/op … e-overview - scroll down to IMU Sensor
https://www.sparkfun.com/products/16832
https://www.sparkfun.com/products/19426
