Sparkfun Lilypad Vibemotor Datasheet
: https://cdn.sparkfun.com/assets/4/a/9/8/2/310-101_datasheet.pdf
https://www.pressabout.com/precision-microdrives-revises-381284/
Hello, I hope you’re doing well!
I was wondering if the current datasheet on the Lilypad Vibemotor is accurate or if the updated version from 2013 is being used. The SKU number matches the parts number at precision-microdrives and the sparkfun datasheet which shows it as having a .8g vibration amplitude.
However the manufacturer of the motor stated in a press release in 2013 (linked above) that the motor (310-101) had been upgraded to 1.2g of vibration amplitude. When I went to look for the model on precision mircodrives website however - I could not find this model. If you have any insight as to which version of the motor is being sold I would greatly appreciate it!
It looks like we use this one now https://cdn.sparkfun.com/datasheets/Robotics/B1034.FL45-00-015.pdf - I’ll get the datasheet swapped out
