Sparkfun Mosaic X-5 Reference Station downloads logs very slowly
Hi I recently purchased a Mosaic X-5 reference station. Pretty awesome unit and the webpage UI makes navigating functions very simple. I have encountered a situation where downloading logged data is very slow (~90kb/s), it previously worked much faster.
I’m using the unit over Wifi, the wifi speeds are up to 100-150Mbps over a local network. So there shouldn’t be this much latency. Anyone got any ideas?
How long was it working correctly?
SD cards can degrade over time, moreso with bigger payloads and frequent reads/writes…not sure if that applies to your situation but I’d first try a replacement card and see if anything changes
Thanks Russell, for the quick response. Maybe about a week ago, it was downloading faster. I’m logging 24/7 to average an accurate final position over time and using the SD card that came with the unit, it tested well before I used it but I’ll try another one. The unit has been running at a constant 55-57°C which seems within the operating temp (I’m in the Caribbean)but I dunno if this is too hot and I should cool it.
Hi @Ryan_R ,
Apologies for the slow reply - I was travelling over the weekend.
We have been making improvements to the RTK mosaic-X5 ESP32 firmware. If you want to, please give the attached firmware a try. It has not yet been released, but it is the firmware I have installed on my test units. The WiFi throughput is much improved, particularly during X5 firmware upgrades over WiFi. I’m hoping you’ll notice a big improvement in your file download speed.
You will need to use esptool to perform the upgrade. Details are here.
We aren’t able to attach zip files directly to these posts. So please rename the file - remove the .txt extension - after you have downloaded it and before you try to unzip it.
RTK_mosaic-X5_Firmware_RC-Oct_19_2026.zip.txt (624.8 KB)
@Ryan_R : one other thing to check:
Please make sure you keep the ESP32<->X5 Ethernet cable away from the WiFi antenna. I have seen interference coupled from WiFi to Ethernet, which introduces errors and slow down the transfers. Keep the cable and antenna separated and all should be well.
Thanks for the guidance Paul, much appreciated. I will do all the above and test, thanks again!
