SWmaps zooming the map in Closer
Has anymore got SWmap to zoom in closer. Under the About tab , frequency Asked Questions it says go to settings and enable Drawing Mode. This will turn off the basemap and let you zoom in further. I am using a Sumsang tablet and don’t see a Drawing mode in settings.
I hadn’t poked around SWmaps in a bit so this ended up being good for me to troubleshoot :slight_smile:
It looks like the FAQ is a bit outdated and ‘drawing mode’ is no longer ‘experimental’…I clicked the larger SWmaps icon in the upper left (main menu) and there are 2 options for UI mode, select ‘drawing’ and it lets you zoom in more
