Technical Inquiry: DEV-19426 Mechanical Dimensions and Product Availability
We are currently evaluating the DEV-19426 (OpenLog Artemis without IMU) as a potential replacement for the DEV-16832 (OpenLog Artemis) in an industrial application.
Before proceeding with our evaluation, we would appreciate your confirmation of the following technical details.
1. Mechanical Dimensions
  • PCB thickness
  • Maximum component height on the top side
  • Maximum component height on the bottom side
  • Overall maximum height, including all mounted components
  • Mounting hole positions and diameters
2. Mechanical Compatibility
  • Are the PCB dimensions and mounting hole positions of DEV-19426 identical to those of DEV-16832?
  • Are the USB-C connector and microSD card slot positions identical?
Our enclosure has a maximum available height of 16 mm, so confirming the overall component height is particularly important.
3. Product Availability and Lifecycle
  • Is DEV-19426 an actively manufactured product?
  • Do you anticipate continued production and availability over the next several years?
  • Is there a product lifecycle or end-of-life notification policy for this product?
4. Technical Compatibility
  • Are the analog input specifications and performance of DEV-19426 equivalent to DEV-16832?
  • Are there any hardware or firmware differences that we should consider when migrating from DEV-16832?
This product may be used in a commercial application with potential future mass production.
Thank you for your support. We look forward to your response.
Best regards,
The good news is all of these will be fairly simple to answer: it is entirely identical EXCEPT the 19426 does not have the IMU and its related circuitry populated.
This is the regular (with IMU) OLA
Here is a photo of 19426 without the IMU
Note the left side compared to the first image
Holes are in the same place, usb, SD, etc…it just has fewer parts on the PCB so you should be all set with your enclosure. We currently have no plans to discontinue it.
Everything else is the same; for actual component sizes poke around the Eagle files…but again the 19426 just has less stuff so any sizing concerns should be alleviated
Thank you for the detailed explanation.
We understand that DEV-19426 has the same PCB layout and connector positions as DEV-16832, with the IMU and its associated components removed.
Regarding the mechanical dimensions, could you please confirm the maximum overall height of DEV-19426, including all components on both sides of the PCB?
Our enclosure has a maximum available height of 16 mm, so we would like to confirm whether DEV-19426 fits within this limit.
If you have this information readily available, we would appreciate your confirmation without needing to review the Eagle design files.
Thank you for your help.
For 16 mm max height the IMU is rarely the problem. USB connector and the mating cable usually eat the height first. Measure board + connector + cable strain relief, not only the PCB stack.
If you are close to 16 mm, right-angle USB or a short panel extension cable helps more than removing the IMU.
Do you need the USB reachable from outside the enclosure, or only for programming on the bench?
Thank you for your clarification.
We understand that the Eagle design files are available for checking the component layout.
However, it is difficult for us to determine the actual component heights accurately from the Eagle files alone.
To avoid any misunderstanding, we do not need to include the USB cable in the measurement.
Could you please provide the approximate maximum height of the DEV-19426 board itself, including all components mounted on both sides of the PCB, but excluding the USB cable?
An approximate value in millimeters would be sufficient.
We need this information to confirm whether the board fits within our 16 mm enclosure height restriction.
Thank you for your assistance.
I’m not sure how to be more direct…the version without IMU has fewer components; it’s size is Less in every conceivable manner and identical otherwise…things don’t enlarge when they are less complete.
An unwillingness to open the Eagle files that we have provided does not generate necessity on our end to do it for ya and then play the telephone game while reporting back…just explore.
I plan to lock this thread soon if something worthwhile doesn’t fruit; for the 4th time: the extreme dimensions are identical and you’ve been able to verify/inspect this for a few days…
If you’re looking to consider this for use in an industrial setting as discussed I would get a unit for testing immediately and proceed from self-verified milestones instead of supposing, if’n you don’t trust the advice given. I would also STRONGLY consider sub-contracting if any of this is perplexing…
I think OP just needs someone to measure the thickness of the whole assembly from the tallest component on the front to the tallest component on the back. A set of calipers should do it, i don’t think you’d even need to remove the board from the bag.
That being said, I don’t have one of these but I’d venture to geuess worst case:
USB C 3mm
PCB 2mm
uSD 3mm
So 8mm thick for the assembly?
Agreed - though if they were previously using the regular IMU one (mentioned in first post) nothing changes size-wise…it has more room. Doesn’t make much sense to endeavor IMO
