Technical Questions About SparkFun XM125 60 GHz Radar – Raw Data and Custom Signal Processing
Hi, I currently own the SparkFun Pulsed Coherent Radar Sensor – Acconeer XM125 (60 GHz, Qwiic), and I am considering using it for a university engineering project focused on radar signal processing and embedded systems.
My main goal is to develop and implement my own signal processing algorithms rather than relying on the sensor’s built-in detection functions.
I would appreciate some clarification on the following questions:
  1. Access to radar data: Is it possible to access raw or complex IQ radar data from the XM125 and transfer it to a computer for processing in Python? If so, what firmware, software, and communication interface would you recommend?
  2. Distance and velocity estimation: Can I use the available radar data to implement my own algorithms for estimating the distance and radial velocity of moving objects, for example using FFT, phase analysis, or Doppler processing?
  3. Additional signal processing: What other radar signal processing applications would be feasible with this sensor, such as motion detection, object tracking, filtering, or classification of different movements?
  4. ESP32 integration: I also have an ESP32-C3 development board. Is it possible to connect the XM125 to the ESP32 and access radar measurement data for custom processing?
  5. Hardware limitations: Are there any important limitations regarding sampling rate, data bandwidth, or firmware that I should consider before choosing this sensor for my project?
    Best regards
For the PC/Python part, there is a documented route: flash acc_exploration_server_a121.bin on the XM125, then use the A121 Exploration Tool or its Python API. That is a different firmware from the presence detector supplied on the SparkFun board. Acconeer’s “How to transfer radar data from XM125” describes the Python route; SparkFun’s “Getting Started with the Acconeer Python Exploration Tool” covers flashing and connecting this board.
One important board-specific limit: Acconeer’s Exploration Tool FAQ says the SparkFun USB-to-UART bridge does not fully support hardware flow control, so set the serial baud rate manually to 115200. I would first capture data on the PC and check whether the usable rate fits your project before moving to the ESP32-C3. I haven’t tested this setup myself, and can’t give you a guaranteed measurement rate or confirm your proposed velocity algorithm from these guides.
  1. See post above; the firmware flashing instructions/links are here Flashing Firmware to the XM125 - SparkFun Qwiic Pulsed Coherent Radar Sensor Breakout - Acconeer XM125 Hookup Guide and the python stuff is on the left. You could also develop your own custom firmware using their SDK if you want (much harder though!). The A121 sensor outputs complex IQ data, not raw ADC samples. The data is organized as a basic frame: N sweeps × M distance points, (each sample = a complex int16)
  2. Sure - you can do whatever post-processing you’d like. Teensy products are good MCUs for stuff like that (or just use PC/laptop/etc). Adapt your algorithms to its pulsed coherent measurement model (not typical frequency-sweep)
  3. That’s kind of up to your implementation…our examples cover some of the basic scenarios
  4. You can either use a qwiic cable (if the esp32 has a port) or UART via the PTH holes to pass the data
  5. Refer to the datasheet and your project’s needs to make that determination
Useful links:
