Hello SparkFun Technical Support Team,
I am a university student working on a graduation project called Muscle Fatigue Monitoring System. Our goal is to monitor muscle activity from three different muscles simultaneously, analyze muscle fatigue, and display real-time results in a Flutter mobile application.
Before purchasing the hardware, I would like to confirm that the MyoWare 2.0 ecosystem is suitable for our project. I would greatly appreciate your advice on the following questions.
1. MyoWare 2.0 Muscle Sensor
- Is the MyoWare 2.0 Muscle Sensor suitable for continuous EMG monitoring and muscle fatigue analysis?
- What type of signal does it provide: raw EMG, rectified EMG, or an envelope signal? Is raw EMG available through any output pin?
- What are the sensor’s output voltage range, bandwidth, and recommended sampling rate?
- What sampling rate would you recommend for reliable muscle fatigue analysis?
- Can we calculate RMS, Mean Absolute Value (MAV), and Median Frequency using the available sensor outputs, or would we need access to raw EMG?
- Which electrodes and cables are required? Are they included with the sensor, or must they be purchased separately?
- Are there any limitations regarding continuous operation, electrode placement, motion artifacts, or electrical noise?
- Can three separate MyoWare sensors be used simultaneously on three different muscles? Are there any recommendations for consistent and comparable measurements?
2. MyoWare 2.0 Wireless Shield
- Does each Wireless Shield contain its own ESP32 microcontroller, or is an additional ESP32 board required for each sensor?
- Does the Wireless Shield transmit raw EMG samples or processed sensor readings?
- Which wireless protocol, BLE service, and characteristic does the default firmware use?
- What are the default sampling frequency, transmission frequency, and typical data rate?
- Can we modify the firmware to transmit timestamps, sequence numbers, and unique sensor IDs?
- Can each shield be assigned a unique BLE device name?
- Is the complete Wireless Shield firmware source code available? If so, could you share the relevant repository or documentation?
- Can the firmware be modified to optimize sampling, packet size, and transmission timing?
3. Connecting Three Sensors to One ESP32 Receiver
Our planned architecture consists of three MyoWare 2.0 Muscle Sensors, each stacked with a Wireless Shield, transmitting data to a single ESP32 receiver.
- Can one ESP32 BLE Central connect to and receive data from all three Wireless Shields simultaneously?
- Is this configuration supported by the official SparkFun example code and libraries?
- Can all three sensors stream data continuously without significant packet loss?
- What are the main limitations regarding simultaneous connections, throughput, latency, and reconnection?
- Can the three streams be synchronized accurately enough for muscle fatigue analysis?
- Which ESP32 board and BLE library would you recommend for this setup?
- If BLE is not suitable for reliable three-sensor streaming, would you recommend another communication method?
4. Sampling Rate, Synchronization, and Data Quality
- Is the sampling rate determined by the Muscle Sensor, the Wireless Shield firmware, or the receiver?
- Does the Wireless Shield transmit every acquired sample, or does it send periodically sampled, averaged, or processed readings?
- Can we obtain timestamps for individual samples or packets?
- What is the expected latency between signal acquisition and reception by the ESP32?
- What methods do you recommend for detecting missing samples, packet loss, and timing differences between sensors?
- Is the available data suitable for frequency-domain analysis, particularly Median Frequency, for fatigue monitoring?
- Are there any example projects demonstrating reliable multi-sensor EMG data acquisition?
5. ESP32 Receiver and Wi-Fi Communication
After receiving data from all three sensors, we want the receiver to combine the readings and transmit them to a Flutter mobile application over Wi-Fi.
- Can an ESP32 maintain three BLE connections while using Wi-Fi simultaneously?
- Could BLE/Wi-Fi coexistence affect sampling accuracy, latency, or packet delivery?
- Which ESP32 development board would you recommend as the receiver?
- Would you recommend WebSockets, HTTP, MQTT, or another protocol for real-time communication with a Flutter application?
- Do you have any example code or documentation for combining multiple BLE sensor streams with Wi-Fi communication?
6. Power Supply and Complete Hardware Setup
- What power supply or rechargeable battery do you recommend for each Muscle Sensor and Wireless Shield?
- What are the typical and maximum current consumptions of the combined sensor and shield?
- What operating time could we expect from a suitable rechargeable battery?
- Are there any special considerations regarding power stability, electrical noise, or grounding when using three separate wireless units?
- Could you recommend a complete bill of materials for our three-sensor system, including sensors, shields, electrodes, cables, batteries, and one receiver board?
7. Purchasing and International Shipping to Egypt
- Could you confirm the current availability of both the MyoWare 2.0 Muscle Sensor and the MyoWare 2.0 Wireless Shield?
- Would you recommend purchasing three sensors and three shields separately, or purchasing Wireless Kits?
- If we purchase three Wireless Kits, would the additional ESP32 development boards included in the kits be unnecessary for our planned architecture?
- Could you provide an estimated shipping cost and delivery time to Egypt?
- Are there any shipping restrictions or documentation requirements for these products?
Our main priorities are reliable simultaneous data acquisition from three muscles, an adequate sampling rate for fatigue analysis, minimal data loss, and stable real-time communication with a mobile application.
We would be grateful for any technical recommendations, example code, documentation, or known limitations that could help us choose the correct hardware before placing our order.
Thank you very much for your time and support.
Best regards,
Dalia
University Graduation Project Team
