UBX & PUBX config ignored
Should this process be this complicated? I thought you just take RX/TX pins, connect it to CH340 and just configure it with U-center v25.06.
Isn’t this like a 2 minute job?
Agreed it shouldn’t be this hard, not sure if it’s a power, or signalling issue.
Kind of why I avoid Made In China off of AliExpress, et al.
The SparkFun or MikroE boards being a better choice.
Yes of course they are, but right now, as a student i can not really afford them :sweat_smile:
I will use this (maybe i will reorder just to test my luck and return it if it turns out bad again) and the M6N to prototype and when i get my PCB i will have a geniune product. Either from LCSC, Mouser or something like that. Configuring it does not seem that difficult if the module works.
Thank you Clive, i appreciate your help, time and patience. Although it did not work out, it taught me more than it would have if it worked on first try. I bet you will hear from me again :grin:
Thanks again.
