ZED-F9R pHAT (HPS 1.00): internal IMU reports no data, ESF-RAW silent
I’m using the GPS-RTK Dead Reckoning pHAT (ZED-F9R) on a Jetson over the header UART (38400, UBX plus NMEA), with a u-blox multi-band magnetic antenna. UBX-MON-VER reports FWVER=HPS 1.00, PROTVER=33.00, ROM base 0x118B2060.
Problem: the IMU never produces data.
UBX-ESF-STATUS:fusionMode=0,imuInitStatus=1(stuck),insInitStatus=1. All six IMU sensor types (5, 13, 14, 16, 17, 18) showfreq=0,ready=0,missingMeas.UBX-ESF-INSis all-invalid zeros.- I enabled
CFG-MSGOUT-UBX_ESF_RAW_UART1=1(RAM layer, module ACKed) for ~5 s and got zeroUBX-ESF-RAWmessages. - Config reads correctly:
CFG-SFCORE-USE_SF=1,CFG-SFIMU-IMU_EN=1, auto mount alignment off, defaults otherwise. Nothing is in flash or BBR. - Under open sky with 10–12 satellites and a 3D fix, stationary for 4 minutes (following the integration manual’s IMU initialization step), the status did not change.
CFG-RATE-NAV_PRIOis known to this firmware (no NAK).
Questions:
Is there anything beyond the integration manual’s start-up procedure needed to get the internal IMU sampling on HPS 1.00?
Is “no IMU data on HPS 1.00” a known issue, and is upgrading to HPS 1.30 the recommended fix for this board? Could you direct me to any resources?
What is the supported update procedure for the pHAT (u-center version, connection, options), and what is the risk to the stored configuration?
Big picture problem I am trying to solve is that 1 Hz fixes are too slow – I want to get on a higher frequency mode and from what I understand, the board can do 15 Hz with the IMU.
Thanks for your help, I really appreciate it!
