Using MAXIM 7218A with Arduino
Continuing the discussion from Using MAXIM ICM7218A With Arduino:
/\*  Using Maxim 7218A with Arduino UNO. (version 1.01)  \*/
const byte ID0 = 2;
const byte ID1 = 3;
const byte ID2 = 4;
const byte ID3 = 5;
const byte ID4 = 6;
const byte ID5 = 7;
const byte ID6 = 8;
const byte ID7 = 9;
const byte WRITE = 10;
const byte MODE = 11;
const byte LED = 13;
void setup() {
//define outputs (data bus)
pinMode(ID0, OUTPUT);
pinMode(ID1, OUTPUT);
pinMode(ID2, OUTPUT);
pinMode(ID3, OUTPUT);
pinMode(ID4, OUTPUT);
pinMode(ID5, OUTPUT);
pinMode(ID6, OUTPUT);
pinMode(ID7, OUTPUT);
//define outputs WRITE and MODE
pinMode(WRITE, OUTPUT);
pinMode(MODE, OUTPUT);
pinMode(LED, OUTPUT);
//defaults
digitalWrite(MODE, LOW);
digitalWrite(WRITE, HIGH);
delay(10);
//send a (negative) write pulse
void writePulse() {
delayMicroseconds(1);
digitalWrite(WRITE, LOW);
//Set outputs ID7-ID6-ID5-ID4-ID3-ID2-ID1-ID0 according to byte 'value'
void writeDigit(byte value) {
digitalWrite(ID0, bitRead(value, 0));
digitalWrite(ID1, bitRead(value, 1));
digitalWrite(ID2, bitRead(value, 2));
digitalWrite(ID3, bitRead(value, 3));
digitalWrite(ID4, bitRead(value, 4));
digitalWrite(ID5, bitRead(value, 5));
digitalWrite(ID6, bitRead(value, 6));
digitalWrite(ID7, bitRead(value, 7));
writePulse();
int pass = 0;
int ledstate = 0;
void loop() {
if (pass == 0) {
pass = pass + 1;  //only do it once
//Set up pins for control word.
digitalWrite(ID4, HIGH);  //normal, no shutdown
digitalWrite(ID5, HIGH);  //1=no decode= control all segments + DP directly
digitalWrite(ID6, HIGH);  //not needed when no decode. (obsolete?)
digitalWrite(ID7, HIGH);  //data coming
//start (positive) MODE pulse, WRITE pulse, finally end MODE pulse
digitalWrite(MODE, HIGH);
writePulse();
//write 8 hex digits starting with least significant
writeDigit(0xB6);
writeDigit(0xF5);
writeDigit(0xED);
writeDigit(0xB0);
writeDigit(0xFF);
writeDigit(0xF0);
writeDigit(0xDF);
writeDigit(0xD7);
//toggle led
ledstate = 1 - ledstate;
digitalWrite(LED, ledstate);
delay(500);  //keep led on/off half a sec
Looks good!
Thanks! I just noticed that part of the code is outside the copy & paste box, do you know how to fix it? Please do if you can.
I edited it; there were some out of place ``` formatting symbols (for our forums you just need to put 3 on a line by itself before code, and another 3 on a line after the code)
