I hope someone can help. I recently purchased an embedded ethernet module - NM7010B from wiznet. Its very cool but it has two double row 14 pins spaced at 20mm and my PCB spacing is at 0.1" (2.54mm).
Isn’t there a socket that does the needed conversion? What can I do?
Digikey is your friend when it comes to finding connectors for small parts. Not only does their catalog list thousands of different types, but they also keep most of them in stock.
All you have to do is find the one you need and redesign your PCB to use it!
