I bought (5 ) 3-watt LEDs from Spark Fun that was cool white, part number com. 13105. This LED gives off a yellowish light and has a wavelength of 6,000 to 7,000 I don’t understand why it gives of yellowish light when it is supposed to give off white light . The color of the light is suppose to be like a fluorescent white, not an incandescent yellow.
Can you take a photo of the bag they came in (label)?
We’re going to take a look at stock and see ensure it’s correct; it sounds like you might have https://www.sparkfun.com/products/13104 in-hand…we’ll get ya fixed up
Hi!
Hmm, I briefly checked our stock today and that label matches what is in the bin for [COM-13105. I didn’t have the correct cable to test with the PicoBuck but using some jumper wires, the dim light appeared to be cool white from one of the LEDs that I tested.
I assume that you are using a constant current driver like the [FemtoBuck or [PicoBuck? Was it only 1 out of 5 that was not lighting up like the others (i.e. giving off the yellow-ish light?).
Let me get back to soon after I test it again with the correct cable and compare it with the one with the warm white to see what is going on.](https://www.sparkfun.com/products/13705)](https://www.sparkfun.com/products/13716)](https://www.sparkfun.com/products/13105)
Maybe try to take a photo of them turned on; our stock appears correct (cool white is barely bluish, warm is yellowy) and the bag appears correct for Cool White
I tested the other ( 4 ) 3-watt LED’s . By themselves they do appear to be white because they are cool white. I think what happened was that the other 3-watt LED’s I was comparing them to gave off even whiter light than the Spark Fun cool white ones. I did not realize this at first and I do appreciate your help in solving this problem.
