4 motor controller for MicroBit
We’d like to purchase the Multi-Chassis - 4WD Kit for programming with Microbit. However, we only see 2-motor controller board for MicroBit. Is there a 4 motor controller for MicroBit?
Not that we carry unfortunately, although it's possible someone else makes one.
If you have enough free I/O pins, it would be possible to connect two [Dual TB6612FNG’s to a microbit to control 4 motors but we don’t have any example code for that. It’s theoretically possible to connect two or more [Serial Controlled Motor Drivers to a microbit as well, but I don’t know if the MakeCode extension would support that. If you’re OK writing your own code, either should work though.](https://www.sparkfun.com/products/13911)](SparkFun Motor Driver - Dual TB6612FNG (1A) - ROB-14451 - SparkFun Electronics)
