4TH AND 6TH ORDER ACTIVE BAND STOP FILTERS
Your guidance was very impressive. Currently am done with the schematic design of the filters. I did it using the NI multism as you directed. Check the attached end results in the document below;
6th order bandstop.pdf (224 KB)
