I have a 7 segment COM-11441 display which works fine when using the demo code shown below
11-2-2012
Spark Fun Electronics
Nathan Seidle
This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
Serial7Segment is an open source seven segment display.
This is example code that shows how to send data over SPI to the display.
For more information about the commands, be sure to visit:
http://github.com/sparkfun/Serial7SegmentDisplay/wiki/Special-Commands
To get this code to work, attached an OpenSegment to an Arduino Uno using the following pins:
Pin 10 on Uno (CS) to CS on OpenSegment
Pin 11 to MOSI
Pin 12 to MISO
Pin 13 to SCK
VIN to PWR
GND to GND
#include <SPI.h>
int ssPin = 10; //You can use any IO pin but for this example we use 10
int cycles = 0;
void setup()
//-------- SPI INITIALIZATION
pinMode(ssPin, OUTPUT);
digitalWrite(ssPin, HIGH); //By default, don't be selecting OpenSegment
Serial.begin(9600); //Start serial communication at 9600 for debug statements
Serial.println("OpenSegment Example Code");
SPI.begin(); //Start the SPI hardware
SPI.setClockDivider(SPI_CLOCK_DIV64); //Slow down the master a bit
//Send the reset command to the display - this forces the cursor to return to the beginning of the display
digitalWrite(ssPin, LOW); //Drive the CS pin low to select OpenSegment
SPI.transfer('v'); //Reset command
void loop()
cycles++; //Counting cycles! Yay!
Serial.print("Cycle: ");
Serial.println(cycles);
spiSendValue(cycles); //Send the four characters to the display
delay(1); //If we remove the slow debug statements, we need a very small delay to prevent flickering
//Given a number, spiSendValue chops up an integer into four values and sends them out over spi
void spiSendValue(int tempCycles)
SPI.transfer(tempCycles / 1000); //Send the left most digit
tempCycles %= 1000; //Now remove the left most digit from the number we want to display
SPI.transfer(tempCycles / 100);
tempCycles %= 100;
SPI.transfer(tempCycles / 10);
tempCycles %= 10;
SPI.transfer(tempCycles); //Send the right most digit
digitalWrite(ssPin, HIGH); //Release the CS pin to de-select OpenSegment
but when I combine it with another SPI device the display is not showing the correct characters; following is the code I want to use
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
7_6_2022 Started file for SKEET COUNTER using EAGLE BOARD "RECEIVE_5_STAND_COUNTER_REV2" FOR SPI
using SPI code example down loaded from SPARKFUN website
7_7_2022 - aDDED ADAFRUIT FRAM MEMORY BREAKOUT PART#1897
7_10-2022 - this is working but display values are not correct.
7-13-2022 - Added FRAM code from John Wasser.
7/26/2022 - Changed EEPROM library to EEPROM_SPI_WE
7/27/2022 - Changed SPI code to use PICKLE_sketch_jula
#include <SPI.h> // Include the Arduino SPI library
#include <EEPROM_SPI_WE.h> //WE
// Define the SS pin
// This is the only pin we can move around to any available
// digital pin.
const int ssPin = 10; //7 segment LED
const int csPin = 14; // WE Chip select pin
EEPROM_SPI_WE myEEP = EEPROM_SPI_WE(csPin); //WE
int t_count = 0;
int high_pin = 5;
int low_pin = 3;
int both_pin = 6;
int reset_pin = 8;
int high;
int low;
int both;
int reset_p;
byte btst[4];
void setup()
// -------- SPI initialization
pinMode(ssPin, OUTPUT); // Set the SS pin as an output
digitalWrite(ssPin, HIGH); // Set the SS pin HIGH
SPI.begin(); // Begin SPI hardware
SPI.setClockDivider(SPI_CLOCK_DIV64); // Slow down SPI clock
Serial.begin(9600);
if(myEEP.init()){
Serial.println("EEPROM connected");
else{
Serial.println("EEPROM does not respond");
while(1);
// You can change the SPI clock speed. The default of is 8 MHz
//myEEP.setSPIClockSpeed(4000000); // use AFTER init()!
//* Select the page size of your EEPROM.
//* Choose EEPROM_PAGE_SIZE_xxx,
//* with xxx = 16, 32, 64, 128 or 256
myEEP.setPageSize(EEPROM_PAGE_SIZE_32);
// Clear the display, and then turn on all segments and decimals
clearDisplaySPI(); // Clears display, resets cursor
Serial.print("t_count HEX = "); Serial.println(t_count,HEX);
Serial.print("t_count BIN = "); Serial.println(t_count,BIN);
Serial.print("t_count DEC = "); Serial.println(t_count,DEC);
// Clear the display before jumping into loop
clearDisplaySPI();
//readEEProm();
Serial.print("Starting t_count = ");Serial.println(t_count);
spiSendValue(t_count);
pinMode(high_pin,INPUT);
pinMode(low_pin, INPUT);
pinMode(both_pin, INPUT);
pinMode(reset_pin, INPUT_PULLUP);
Serial.println("File name = SKEET_7_5_2022_SPI_FRAM_E");
Serial.print("COUNT = ");
delay(1000);
void loop()
high =digitalRead(high_pin);
if (high == HIGH)
Serial.println("high_pin");
t_count = t_count + 1;
Serial.print("HIGH COUNT = ");
spiSendValue(t_count); //Send the four characters to the display
sendEEProm();
delay(1000);
low = digitalRead(low_pin);
if (low == HIGH)
Serial.println("low_PIN");
Serial.print("LOW COUNT = ");
sendEEProm();
delay(1000);
both =digitalRead(both_pin);
if (both == HIGH)
Serial.println("both_pin");
t_count = t_count + 2;
Serial.print("BOTH COUNT = ");
sendEEProm();
delay(1000);
reset_p =digitalRead(reset_pin);
if (reset_p == LOW )
Serial.println("reset_pin");
t_count = 0;
sendEEProm();
delay(1000);
clearDisplaySPI();
Serial.println("At spiSendValue");
Serial.print("tempCycles, BIN = "); Serial.println(tempCycles, BIN);
Serial.print("tempCycles, HEX = "); Serial.println(tempCycles, HEX);
tempCycles %= 100;
tempCycles %= 10;
void sendEEProm()
myEEP.put(10, t_count); // write an integer to EEPROM address 10
Serial.print("sendEEprom READ = ");
void readEEProm()
myEEP.get(10, t_count);
Serial.print("raedEEProm = ");
// Send the clear display command (0x76)
// This will clear the display and reset the cursor
void clearDisplaySPI()
SPI.transfer(0x76); // Clear display command
// Set the displays brightness. Should receive byte with the value
// to set the brightness to
// dimmest------------->brightest
// 0--------127--------255
void setBrightnessSPI(byte value)
SPI.transfer(0x7A); // Set brightness command byte
SPI.transfer(value); // brightness data byte
// Turn on any, none, or all of the decimals.
// The six lowest bits in the decimals parameter sets a decimal
// (or colon, or apostrophe) on or off. A 1 indicates on, 0 off.
// [MSB] (X)(X)(Apos)(Colon)(Digit 4)(Digit 3)(Digit2)(Digit1)
void setDecimalsSPI(byte decimals)
SPI.transfer(0x77);
SPI.transfer(decimals);
The following is an example of t_count input and the DISPLAY output display but these are not always the same.
t_coun = 0, DIsplay = 1111
t_count=1, Display = 3113
t_count=3, Display = 1513
t_count=4, Display = 7517
I have tried different EEPROMS, FRAM etc and several codes but the result is always the same.
Help appreciated.
Bill
