hello,
I have some questions about the STM32-103STK board from Olimex :
- As most of the proposed projects are under IAR format, I use the kickstart version but the Nokia 3310 LCD is not implemented anywhere.
(including Olimex & IAR docs as IAR support that board)
How to drive it please ?
same question for the accelerometer
are the C sources from ST 100 % compatible ? for example does the firmware will work “as-is” without modification or are there some risks ?
Thanks in advance
