My company is looking to purchase hardware for the measurement of distance and velocity in the weight room. Here is an example of what others are using:
6 DoF inertial measurement unit consisting of:
1 3D Accelerometer
1 3D Gyroscope
Data collected at 1000Hz
Can you help steer me in the right direction? I can connect you with my tech team for more details.
Greetings, egrossmantraining. Thanks for posting on the forums.
If you want to give Sales@SparkFun.com an Email with as many details as possible about this project I am sure they will be capable of pointing you in the right direction.
Cheers and best of luck!
I’d recommend the [ICM-20948. It includes the two sensors you need as well as a 3D magnetometer.](https://www.sparkfun.com/products/15335)
Thank you! I’ll look into the sensor you recommended and follow-up with sales if need be.
