AD9850 Generate Random Fixed Frequencies Controlled By MEGA328P-AU
Hey
I’ve made a circuit with AD9850 Controlled by ATMega328P-AU with serial interface.
Here is the Schematic Link.
https://gofile.io/d/ShIaPi
I’ve Tested Prog with AD9850 Module (HC-SR08_Module) and code is working.
Circuit use a 3.7v Single Cell Li-Po Battery and MT3608 to Boost 3.7v to 5v.
The Reference Oscillator for ad9850 is 2 MHz .
I’ve Reduce the code to just set the frequency of ad9850 But it generates few fixed random frequencies .
for instance:
Desire Freq ----> Output Freq
1 KHz ----> 900 KHz
2 KHz ----> 3.9 KHz
3 KHz ----> 15Hz
4 KHz ----> below 2Hz
5 KHz ----> 899 KHz
and so on…
every time i change frequency , the output frequency is a random value between above.
I would appreciate any help.
